  • Assign an IPv6 address to the interface.
  • Enable routing globally.
  • Change the VRF instance as required to configure VRRP notification control on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
Perform this procedure to configure VRRP notification control.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select VRRP.
  3. Select the Globals tab.
  4. Select enabled.
  5. Select Apply.
Use the data in the following table to use the Globals tab.
Name
Description
NotificationCntrl
Indicates whether the VRRP-enabled router generates SNMP traps for events.
  • enabled: Generate SNMP traps.
  • disabled: Do not generate SNMP traps.
The default is enabled.
